Can anyone explain how to remove the tilt assembly on a 1993 Evinrude 40hp? I have it raised up and i removed the clip on the pin that attaches the piston to the stern bracket. How do I remove the pin itself? It seems stuck and I'm not sure if there is some trick. Maybe I'm doing it wrong altogether.
I have a repair manual on order, hopefully it will help as well.
It looks as though on the starboard side where the pin is it is threaded. I assume I must screw in a bolt and use a slide hammer to remove the pin?
