My outboard has a 'long' lower unit and originally had a prop drive. It appears that sometime in the recent past the prop drive was replaced with a jet drive and a jack plate (just the plate, it's fixed) was installed to raise the motor a couple inches.
I've heard that prop drives develop 30% more power (?thrust?) than jet drives. It also seems like the long shaft is less popular and less available than the short shaft.
The boat is a 1998 16.5' Alumacraft center-console, modified V, and tunnel. The primary use of the boat is the shallows of the middle Texas coast. Does someone please provide me with their opinion on this setup?
Sorry in advance if this is not the right forum for this discussion.
