I just recently bought a used boat that is equipped with a 1998 Johnson Venom. The boat and motor is in excellent condition, however I am having some issues with the motor. For one, after I start it, it doesn't want to idle very good. It's like it just chokes out and dies. If I put it in gear to the first notch, it still want run real well without giving it a little extra fuel ever now and then, kind of having to play with it. When running at any other speed above idle, it does great. I would appreciate any advice on what to check first and so on.
The other problem is, this past weekend I was running down the lake and I started to slow down as I reached my fishing spot. As the boat came off of plane, the low oil light and buzzer came on. I immediately killed the engine. The oil resovoir was at least half full if not three quarters. I trolled all the way back to the ramp afraid to run the engine. I would greatly appreciate any guesses on what might cause this and also could there be any damage from oil starvation since I immediately shut the engine off?
