1990 48spl Evinrude Pulse Equalization hose
Froggerman
On top of my carburetor there is a hose connector **** that is L shaped, that is i guess pressure fit into the top of the carburetor. If im correct its called a Pulse Equalization hose connector.
My question is this.
What does this hose do, or its purpose ?
Also the L connector has come loose from the top of the carburetor. I can push it back in but not sure if it is going to stay in. While running, my motor started idling to low and had hard time running. I found it to be off. I pushed it back in.
My question about this is.
Can I put a small amount of JB Weld on it to insure it stays seated and wont come disconnected again?
I know not to get any into the hole.
Or should i maybe solder it or something?
Also i idled my motor up a hair when i got home and it seems to be running fine now.
But do want to know how to insure my L connector wont come out again.
Thanks for your help
Frogger
(Wally)
Froggerman
Re: 1990 48spl Evinrude Pulse Equalization hose
So many posts here might be tough to be seen, since the posts move so quickly down.
Daviet
I couldn't find the fitting you are talking about in the parts breakdown, but I have had success using JB weld to reinstall fuel fittings in carbs.
Froggerman
Here is a picture of the elbow that comes out. Ive drawn a white arrow pointing to it. Almost center of the picture. What purpose does this tube do? thanks for your help.CarbPic1.jpg
Daviet
Still can't find it, what is your model number?
Daviet
It's not shown on the parts breakdown I am looking at, where does it go, to the top of the other carb?
Froggerman
Yes exactly. It goes to the top of the lower Carb.
Froggerman
Is there a breakdown part picture www page i can go too to look ?
Daviet
Does it splice off from the carbs and go to the crankcase?
Froggerman
That specific hose only goes from the top of top carb to the top of the bottom carb.
Froggerman
There is another hose you can see in the picture i posted not sure where it goes. Sorry not up on all the names and parts as of yet. Know what the carbs are though LOL
Froggerman
Thanks
The tube that is there puts alot of black on your fingers when touching it so im assuming its broke down and old. So Im guessing i should replace it while im gluing that joint down. Would you use JB weld to adhere that joint to the top of carb?
Daviet
That's what I normally use, just make sure and clean the fitting and where it goes in really good. I use brake kleen.
Froggerman
ok Thanks for your time and support.
Daviet
You're welcome, sorry I couldn't be more help on the hose question.
