I have a 1991 Johnson 40 hp outboard that I am trying to troubleshoot. For some reason once the motor gets to warm operating temp it begins to sputter and shake really badly. Once this happens the motor will idle just fine and work for any RPM under 2500 or so. So far I have done the following: Compression check(good), replaced coils(old were cracked on bottom), cleaned carbs, ran fuel out of good fuel gas can. I am leaning towards a power pack issue but was looking for a way to test before I shell out $100+. Does this sound like your typical power pack issue? How can I test the power pack? Mine is located under the flywheel so testing during the hot condition might be a challenge.
