Can anyone reccommend a way to remove the tilt tube from the stern bracket. I have the motor off and the stern bracket removed from the tube on the port side. The starboard side will not budge though.
Re: 1976 55HP Evinrude: How do you remove the tilt tube from the stern bracket?
Thanks. Went to the hardware store and bought a torch. I was finally able to pound the tilt tube out without breaking anything. I had the same problem and solution with the arm and shaft. Thanks for the response.
