I have a 1996 130 hp evinrude. The motor will start fine and idle good. But when put into drive or reverse the motor quits (like you shut the key off ) . About one every ten times it will go into drive, then runs good and gets up fine and goes . Have put new plugs in , change the fuel filter, run dry gas all the time and have tried sea foam. COuld it be a fuel leak and allowing air in ? Could it be ignition module ANY HELP ? ?
