Thank you for your help everyone!
I have a 1995 Four winns jet boat with a 115hp OMC which to my understanding is a 115hp Johnson.
The boat when held at WOT just bogs unless you hold the primer key in and then it accelerates. I pulled the carbs and they are perfectly spotless! Just want to know what direction to go in next??
Thank you
Brian
BrianDegener@gmail.com
Thank you
Brian
