The service manuals states the fuel mix ratio is 24:1 for 1960 and 50:1 for 1962. What changed between the years
The reason I am asking is that I want to run a higher ratio in my 1960 but not sure of the mechanical reason for the recommendation differences.
The motor starts right up, idles at 800 rpm, plugs are a nice light brown, compression is 110 on cylinders but when on the slow jets she smokes so bad it is hard to be in the boat.
I also noticed when comparing the two that the 1960 has adjustable main jets where the 1962 is a fixed main.
It seems that even these motors look very similar there are some big differences in mechanics that need to be considered
