Getting spark to all cylinders.
Compression excellent all cylinders.
New power pack and rectifier installed last year.
So here is the deal- when I open her up she goes nowhere
for at least a minute. Definitely struggling to pick up speed.
When she finally planes, the tac is only reading 4200 rpms.
This engine should be running approx. 5700 rpms WOT
Nowhere near the speed and power she usually runs at.
When testing at dock - dies out on 3 of 4 cylinders when I spray starting fluid in carbs- BUT
if I am running her at WOT on the water and push in choke, she starts to die which
usually signifies it isn't a carb problem.
Idles great and runs smooth at low speeds.
Any ideas what is wrong????????
