On my way home I saw this little motor in a Trash bin. So being me I had to stop to grab it. Took it home and started cleaning the housing and lower unit. After that I spun the motor by hand and it turns with the feeling of compression in the cylinder. I have yet to pull the plug and check the carb. But the tank is rust free and did not check if the prop spun when I turned the motor over being a direct drive to the prop I think. I am not 100% of what all the items on the front of the motor actually do and if the throttle is controlled by the wing on top of the motor where it says Stop Start Fast. any help on this engine would be apriciated. This is a perfect little motor for my jon boat and is light so I can carry it any where.
