Re: pistons/ crank 1972 6hp johnson
if you have it apart to that degree, id look into new bearings, dont remove the rings unless you can get new/or plan to replace. you should be able to move the rings slightly, a small amount ..very small rotationally, and be able to compress them a small amount also.
