j_lardinois
- Jul 12, 2011
- 3
Guys I am newer to the forums so I hope I am approaching my questions the correct way... I am looking to replace the coils, condensers, points and plug wires on a 1970 Johnson 40hp model #40ESL70A. I purchased all of the parts I need and have a manual for the outboard. I do not own a flywheel puller, is there any tools that would work to pull the flywheel without damaging it? Or should I just go ahead and purchase a puller? Also does anyone know if it will be neccessary to replace the seal after pulling the armature plate, or should I be able to reuse it?
Thank you in advance for the advice
