Pretty much as the title states, but here are the details..
Last year after tubing, I had to switch tanks is when it started. I replaced the plugs and wires on the lake, no change. Would not idle, shook terribly when the fast idle lever was used. I have since removed the carbs, and have completely and thoroughly cleaned them, performed a compression test, 120# on all cylinders, along with replaced 1 defective ignition coil. Still experiencing the same symptoms.. I'm starting to develop a raw spot on my head from all the scratching, and am now turning to you guys for some help.
Any advice on where else to look would be greatly appreciated!
