Hi, first time poster here.
Managed to remove most/all of my skeg on a rock. To repair am disassembling the gearcase so the welding doesn't cook seals & bearings.
The lower unit is off the motor, and am carefully tearing it down. I am to the point of removing the drive shaft and the prop shaft, but don't know how to proceed. There is maybe 3/8" vertical play in the drive shaft, but it doesn't come free, and I don't want to apply force and break things. I'm assuming I'm missing a step somewhere.
The model number is E120TLERC.
Another question: When shifting, how much play/slop should there be between forward and reverse?
Thanks!
Thanks!
