The no oil alarm sounds on my 2005 Johnson 150 at low RPM's or idle in or out of gear after about 4 or 5 minnutes. The oil tank is full of oil. I can turn off the engine and restart and the alarm does not come on again until I run it at idle or low RPM's. Any suggestion's on the problem? The check engine alarm did sound one time during a recent outing but only once and this was at about 4500 RPM's.
Thanks for any help
Thanks for any help
