robsteinny
- Jun 13, 2004
- 19
Hey guys. I have a 99 Johnson 225, model # J225TXEEC
There is very little power going to the engine. From the helm, the motor will not crank (nor click) and the trim/tilt does not work. When I attempt to opertate the trim/tilt directly from the engine, I can hear a faint buzzing noise.
Sporatically the trim/tilt will work directly from the engine, but never from the console.
I also smell a slight burning/shorting odor when I stick my nose directly in the engine.
I looked for a fuse in the harness and on the motor but could not find one. Do you think the fuse could be the issue and if so, any idea where it's lcoated?
If not the fuse, what else might be the problem?
Thanks in advance!
-Rob
Thanks in advance!
-Rob
