matthewp
- Jul 14, 2008
- 173
Hey guys,
Haven't been around in awhile. I just repowered my starcraft with an '02 johnson 115 - 2 stroke. Haven't run it much yet -still getting everything right. So here's what it's doing:
1) starts great - alarm tone sounds normally when turning key on and then goes off. all warning lights on tach go out after a few seconds. motor runs great so far.
2) when it's running, the alarm emits a very high pitched tone at low low volume - but you can hear it. different than the start up tone, which is loud and unmistakeable.
When installing, I tapped into the purple wire on key switch (accessory circuit - same one that powers alarm) to power my other gauges.
Any thoughts you guys have would be greatly appreciated. Thanks!
