1990 Evinrude 140
About a year and a half ago a shadetree mechanic (who for a price taught me that it was best do to my own work and that's about all I got for my money..) replaced my head gaskets (and broke a few other things). He clearly didn't tighten them down very well and there's been a fair amount of leakage. For a while I had been getting a tiny bit of gunk buildup around the head bolts. Barely anything. Then suddenly it became a lot so I'm changing them. Again. I'd managed to convince myself the water got there from the slightly cracked and leaky thermostat cover that came on a head he swapped out for me (which had a broken thermostat bolt when I bought the motor). Thanks, guy. Lately its gotten really bad so I'm finally replacing them.
As long as I have it all apart I thought I'd get a few opinions on the condition of these internals. These pics are the port side. It looks like there is a little bit of scoring in there and I'm wondering if this is bad scoring or normal wear.
The compression is port top 135 port bottom 125, and both starboard are 135. I suppose part of the low compression on that one cylinder could be due to the fact that the head gasket just wasn't very tight.
And how about that carbon buildup? I did a concentrated sea foaming about a year ago and I'm due for one now, but while this is apart can I just scrape that out and then blow it out with my air compressor? Or is it even that bad?
