Pecenje
- Jul 1, 2011
- 41
Hi, I'm new to the forum... Hope i will be able to help others out also...
I have a single lever side mount control for my 99 johnson 25HP (2cyl)
when i bought the motor it came with the old school 2 lever shifter...
i picked up the single lever newer style for it...
the old school shifter had the warning horn wired to it...
the new shifter doesn't (not that i can see at least)
Do i need the warning Horn?
Is there a way to test if it has a warning horn/if it's working properly? without opening up the control...
Does anyone have a wiring diagram for the 3 pin tach plug...
this is all i'm able to find...
I know it's a ground, 12V and tach signal but which pin is what?...
starting from left to right?
any help would be appreciated
Thanks,
Thanks,
