So i have a 30hp johnson 2 stroke that I've had since new and it has been running like absolute crap lately.
To get it started it requires abusing the electric start and playing with the throttle. It only seems to run in Neutral if i crank the throttle wide open and ease off little by little and even then it wont make it down to a nice idle speed.
It all seemed to start out by backfiring at lowish rpm(no wake zones) and instantly dying. Now it runs like crap under half throttle. I managed to drive it on the trailer last time as i usually do, but it didn't have the power it usually does to get it all the way up the trailer.
I have taken the boat out ~5-6 times this season and at the beginning of the season it ran WAY better than it did now. So far i have replaced the plugs, drained the bowl, and taken the plastic fuel inlet cover off the carb and blindly sprayed some carb cleaner.
The motor has 60-75 hours on it i'd say.
Thanks in advance
Thanks in advance
