Hi guys, I am new to the forum, and fairly new to boating. I purchased a 1971 Arrowglass boat, with an 100 hp starflite engine. The power pack was fried on it, and was able to find an aftermarket unit on ebay. After replacing the power pack as well as the coil, I put the key in and nothing happened. The battery was completely charged, and I'm fairly certain I hooked the power pack and coil up correctly. I am fairly mechanical but just don't quite know where to start. I don't hear any clicks from the starter solenoid. We were able to take jumper cables and short the solenoid, forcing the motor to crank. This did not start the motor however. Any help would be much appreciated. I was wondering if the key switch is out? idk? Thank you for any help!
PS- This engine has an electronic shifter? I have never seen such a thing, and wonder if this might be part of the problem?
Micha
Micha
