I have been searching several boards and have found similar problems, but nothing definitive. I have an 87 Johnson 120 on my Proline and when you depress the key to engage the primer you hear solenoid engage, but no fuel is sprayed out. The engine starts up on the first try out of the water, but no dice while in the water when the engine is cold. The neighbors are starting to complain about firing the engine up at 4:30 am in the middle of the week so I am looking for any suggestions to get it fixed. The carbs were just cleaned, new fuel tank and lines, non-ethanol fuel, yadda yadda. Any tips on where to start?
