So I bought a boat and took it out. It was running rough so I replaced fule and vacume lines. Took it back out and ran good for a while and then was falling flat when accelorating. When I got it back in one plug was badly fouled and the the piston was damaged. Cleaned the carbs and took it back out and ran good for about an hour then started running rough and falling flat. So I then pulled the head and cleaned all the carbon out and the piston (see pic). Now it runs good sometimes but stalls and there is a thump sound, kind of like a misfire. I think it is predetination.
So the question is can I get this thing to run good enuff to take out again???
Mybe a different plug in that cylender or bigger gap? Help
