blindfury420
- Jun 21, 2011
- 2
Hello! I have a problem with the new and old ignition. Long story short, 1984 riviera cruiser with a 25 hp evinrude (77) was working fine, key broke in ignition and with some pliers key still worked. In the morning tried to get a key made but just decided on a new ignition.
Didn't buy from here, but it is this one http://www.iboats.com/Sierra-Ignition-Switch/dm/view_id.47122
My dad got home with part and decided to do it. He didn't label any wires before and must have mixed wires cause now even the old one wont work.
I'm assuming cause neither of us know how it was setup before. I have pics attached on how its wired back on old ignition but after the failed new ignition and mixed wires.
Does anyone know the correct way this should be wired? Also push button electronic choke and battery is fully charged.
I just don't know if the wires are correct like if previous owner just chose to use what color they had. I saw this reading around but wires don't match right,
Black wire = Connect to one "M" terminal (magneto)
Black wire = Connect to other "M" terminal (magnetio)
Green wire = Connect to "B" terminal (battery)
White wire = Connect to "S" terminal (solenoid)
Red wire = Connect to "C" terminal (choke
Am I gonna have to chase down each wire and then label, so color doesn't matter if it even is wrong?
