1991 Johnson 120 Hp. Two weeks ago went out fishing when I went to pull anchor engine would not start. No spark had to be towed home. Performed test for stator per service manual and failed tests. Resistance was reading open and no voltage. Picked up a used stator installed and tested was within specs. Took boat over to a nearby canal for a test run and engine ran great. Tried to go fishing on Saturday and engine ran fine then after about an hour of running engine quit. No spark again!!! Once again had to be towed home. Thank god for my tow membership. Checked stator at home and the new(used) stator also failed. What could be causing the stators to go bad. Do you think the used stator was just on its way out or could something be damaging them. Any help would be greatly appreciated.
