Re: 1971 Evenrude 100 hp correct battery?
Your motor has the battery CD system with an amplifier, not a "power pack". With that cleared up, the amplifier gets its power from the battery / alternator system. The charging system is not voltge regulated, the battery being the only control over the voltage. It is thought that that is the problem that kills the amplifier, and the battery type may have some effect on the voltage. At some point in history, they did say not to use maintenance free batteries.
Personally, my opinion is that if it is a known problem, then why aren't the mfrs of the new amplifiers including some sort of input voltage regulation within the amplifier? It could be done with a couple of dollars worth of parts. Maybe they are, maybe they aren't doing it, I dunno. Seems like a gross irresponsibility not to.
