Hello Folks,
I have a 1987 Johnson 4.0 Deluxe outboard (Model J4RDHCUD) that I am reviving after it sat on the back of one of my sailboats since the last millenium.
My budget is EXTREMELY tight, which is why I haven't gotten a manual yet, so I'm trying to get things done as cheaply as possible.
After dosing it with some PB Blaster small engine tune-up stuff per can directions, and adding some "mechanic in a bottle" to a fresh mix of gas & oil, and cleaning the plugs, that sweetheart started on the 3rd or 4th pull!.
I've got it mounted on a sawhorse with the lower unit in a huge bucket (30 - 40 gal.?).
The only place I've seen water exiting is from the exhaust port at the top rear of the unit, where it is like a spray/spitting type flow, and from two holes about where the lower unit joins the shaft. The holes are at the front on either side. That flow is more of a pulsing/spitting type thing.
I've been monitoring the motor temp by feel, and even after 10 - 15 minutes running at various speeds, I haven't felt any areas that are untouchable hot.
My question is:
Does anyone know if what I have described is the normal operation of the cooling system on this particular model?
I'd appreciate any and all responses to my question.
Thanks in advance,
Rick Trahan
My question is:
Thanks in advance,
Rick Trahan
