-I have 2005 Johnson 150 V6 outboard that stalls around 2000 RPM while in gear in the water.
-It set up for about a year, then I ran it, it ran like crap.
-I changed the plugs (they looked wet), pumped out the old gas, put it new gas with sea foam added and ran it for about 2 hours in the water. Again ran like crap. It runs OK in the yard on rabbit ears I can manual throttle up to 5000-6000 RPM and put it in gear and get up to 4000 RPM. It the water and in gear it stalls around 1500 RPM.
-I sprayed some valvtech de-carb in the carbs while running, following all direction on the can. I ran it for about 2 more hours in the water and can get about 2000 RPM while in gear. Again in neutral I can get about 5000-6000 RPM on it or out of the water it will run up to about 4000 RPM on the rabbit ears. Only time it stalls is when I throttle up in gear in the water. All spark plugs are producing spark I checked them individually.
-Any ideas, I am trying to get it running with out taking the carbs completely apart and cleaning them. I know it will need this eventually but am hoping I can get it going without that.
I am very green when it comes to Outboard engines. Any help is appreciated.
