Re: 1988 Evinrude V4 120hp Wet Test Compression Results Good or Bad?
you might...can you get it to run ??do this if you can...
first put a little splash of seafoam into the cylinders with the engine tilted up let it soak for one hour turn the engine over with the plugs out to blow out the excess seafoam and to prevent hydro lock
then
do a shock treatment decarb take a gallon of gas 3 oz of two stroke oil and 2/3rds of a can of sea foam and mix it all up in a seperate can run the engine on this mix and spraying the remainder of the seafoam dirrectly into the throat of the carbs while its running run it until the gallon of gas mix is gone ive heard this is best done while on the water but i cant see why you cant do it on the hose if you have to
if you do it on the hose keep the rpms low (below 2k) or you can get a runaway condition and trust me you dont want one of those
oh yeah and its gonna smoke so bad youll think your blowing it up, your neighbors will hate you for a week, and your mosquito problem (if you had one ) will be no more
but keep it running thats the carbon burning off the rings and all the internal parts and dont be surprised if the prop starts oozing black goo from the exaust its normal thats how you know its getting clean ;D
retest the compression when your done and see if the numbers on that low cylinder comes up you numbers are borderline on that cylinder but it may come up after this procedure post back your results
