Hi
I lost part 40 shown it the schematic shown in the link that follows. It was a stiff piece of wire. Can anyone tell me what it does and if there are any key things I have to keep in mind if I try to make another. Is there anyplace I can find specifications for part 40? I started to take the carburetor apart to clean because the motor only runs only at high speed and will not idle.
If you have a J3BRESR and can look under the cover at the carburetor it would be appreciated. I suspect that either part 40 limits the amount the choke closes or limits its movement in someway. but with out the actual part I can't tell what it does. I picture of the left side of the choke would be fantastic!
http://www.boats.net/parts/search/BRP/JOHNSON/1990/J3BRESR 1990/CARBURETOR/parts.html
