2005 Johnson 90 HP shifting into neutral problem
Bronx68
I have a problem coming out of gear and going into neutral. The boat is a center console and when I shift into neutral there is not a positive out of gear detent or stop. Is this a simple adjustment? I brought it to a dealer and he sat on boat for two weeks before he adjusted cables. He said it was fine but still have the same problem.
Re: 2005 Johnson 90 HP shifting into neutral problem
Do you mean it is hard to find N on your remote control? If it is hard to shift from in gear to nuetral I would suspect the shift interupt switch functioning properly.
Bronx68
When coming out of forward gear, I must go past the detent in the shifter in order to get the engine out of gear. Which cable (upper or lower is the shift)? I believe I need to adjust the cable.
