The engine surges at wide open throttle. It gains power then dies off, feels just like it's picking up a cylinder or getting a burst of fuel. Or if you were at wide open throttle, pull back then lay into the throttle again. Just like a surging.
I have had this problem for some time already. I don't think it is fuel related as I have been through everything. I have cleaned carbs twice, reed valves are fine, fuel bubble is good. I also tried without the fuel bubble. No change. Fuel filter is clear and also even tried a different fuel tank. No change.
I have tried a couple of different control boxes thinking maybe something in the wiring was bad. No change. I also have tried new plugs and swapping all the coil packs around with a known good one also no change.
What do you guys think? I have not tried plug wires yet. Anything else I could be missing?
Thanks
Thanks
