Re: stuffing cylinders with nylon rope to remove flywheel
Welcome aboard jjpears!!
I moved your post to a thread all its own, so that it doesn't get confused with the previous one. I have left a link for reference. We like to keep each member's particular issue separate here. Thanks for joining iboats forums
flywheel pulled off with puller using bolts on flywheel......not from outside ring of flywheel (do not use jaws that grab the outside). at least that is how almost every johnnyrude and merc i have dealt with recently worked.
