How do you replace the Impeller on a 1979 70HP Johnson motor?
N Nelson F Recruit Joined Jun 1, 2011 Messages 1 Jun 1, 2011 #1 How do you replace the Impeller on a 1979 70HP Johnson motor?
B boobie Supreme Mariner Joined Nov 5, 2009 Messages 20,826 Jun 1, 2011 #2 Re: 1979 Impellor 70 HP Johnson - how to repair Get an OMC factory service manual, some tools and go to it.
J JWhit Petty Officer 2nd Class Joined Mar 29, 2010 Messages 130 Jun 1, 2011 #3 Re: 1979 Impellor 70 HP Johnson - how to repair many posts on this, but basically disconnect shift linkage, unbolt lower unit, slide entire lower unit out, replace impeller and then put back together. service manuals are worth every penny
