Re: 1976 Evinrude 55 HP water pump o ring and gromet
The o ring is for the top of the driveshaft, beneath the splines. Do not forget to replace this or you may have trouble dropping your gearcase the next time. A bit of marine grease on the splines in needed as well. As mentioned, the grommet is for the water line. Be careful not to pinch the grommet with the water line when lining the gearcase back up or you will have no water flow. Great motor, I have the same one.
