I have a 1998 90hp Evinrude, but I?m having an issue with the motor dying on me. It run fine the first couple of times that I had it on the water. And then it just started dying. The first thing I noticed is that I have to crank the motor for about a minute or a minute and half before the motor will start. I?m using a primer bulb to prime the pump but it seems like its not getting enough fuel. The motor would run fine across the water for about three (3) minutes then the motor would die. I would have to prime the bulb each time, (the primer bulb seem a soft, but I can still feel fuel in the bulb) but each time the motor would start and quickly die. If I continue to pump the bulb, the motor would stay running, but loses power. I don?t know if it?s the bulb or the fuel pump. Need a little help, I had the compression checked, new plugs, new wire, new power pack, new coils, new starter, new fly wheel, new fuel pump primer and new hoses.
