Welcome Guest - Sign Up today
Store Links Mobile - Shop Now
See more
See less
1976 Evinrude 25hp clutch dog
  • 1976 Evinrude 25hp clutch dog
    I have a 1976 25 hp evinrude and I need to know how to take the clutch dog out to replace it?
    Re: 1976 Evinrude 25hp clutch dog
    Heres a schematic of your motors gearcase http://www.crowleymarine.com/johnson...arts/40695.cfm
    Remove the shift shaft connecter from the oval plate on the exhause housing,Drop the lower, turn the lower upside down,remove the phillips head pivot screw,then remove the six screws that hold the lower part of the gearcase with the skeg on it.The shift shaft will then come out for your replacement.
    Why are you replacing the dog? If its popping out of F gear, the F gear will most likly be bad also.
    • #3
      It is starting to jump like i hit a log going down the river not sure yet but I need to get to it so I can look at them.
      • #4
        Do I have to remove the whole lower end or can I just take them six screws and get to the clutch dog?
        • #5
          It would be easier to remove the lower unit. Is it time to replace the water pump impeller, perfect time to do it.
          Back to Top
