I need to tap into the expertise of this forum. I am working on a boat (fairly new to boat maintenance). It has a Evinrude 135 HP that he bought to put on this boat and the power tilt isn't raising the motor up. You can hear the motor running when trying to raise it but no movement, you can hear the motor click when you try to lower it but the motor is all the way down at this time. It worked a couple of times after he brought it over the other day but after I lowered it all the way down the last time it hasn't moved in the up direction since.
Any help is greatly appreciated on this matter.
Thanks,
Rick
Thanks,
Rick
