harrylarson
- May 7, 2011
- 27
This concerns a post I had started previously, my 74, 115 hp, Evinrude barely runs after idling for about 15 minutes. Put inductive timing light on wire for each cylinder, 1 & 3 seem fine, steady strobing light. 2 & 4, the other bank, the light seems intermittent and weak. Could someone please confirm what I understand to be a test of my Power Pack? Switch orange ignition coil wires at Power Pack for cylinder 1 & 3 with ignition coil wires for 2 & 4, respectively, if problem jumps to the other bank then the Pack is bad. Yes? Also is it OK to start motor with the wires swapped? Because I don't know if I can check the inductive light when just turning with the starter.
