dockrat100
- Mar 22, 2011
- 144
I have a 1981 Evinrude 4hp that was running, albeit not really well.
I discovered that the water pickup tube was plugged, and proceeded to tear down the lower end below the powerhead to clear the coolant passages. After four broken bolts, alot of new gaskets, and new parts, (thanks to the broken bolts), I put the motor back together and tried to start.
I have no spark to my top cylinder, and small plumes of smoke coming from the magneto. Did I fry a coil somehow? I did use a lot of carb cleaner cleaning the powerhead, some of whick may have dripped onto the magneto. What to check next?
