I have a 1985 Johnson 200 hp outboard that has been stored for about a year. My power trim motor works good in the up and down positions but the engine does not move. I can pick it up by hand but the cylinder will not move when the trim motor is running.
Can I add fluid?? If so, does the motor need to be in the up position? How do I bleed the air?? Any help appreciated..
