I have a 1986 Johnson GT-150 outboard with the 35 amp alternator. Lately I have noticed that my volt meter has started reading up to 15.5 volts while at WOT. The sonar unit I have displays the supply voltage and it too shows ~15.5 volts while at WOT. When at idle the voltage reading is ~12.5 and it steadily increases as I accelerate. In the past I only remember the max reading to be ~13.5 volt max. Could this be caused by the starting battery going bad or is it most likely the rectifier/regulator going out. Even after running the electronics all day the battery seems to easily start the motor, just not sure if this charging voltage seems excessive. Thanks in advance for any comments/recommendations.
