Re: 1988 Evinrude 60hp Tach wire
The grey wire starts at the wire connector strip on the starboard side of the motor, into the harness, harness from the motor to the console and it is hooked up to the tach. On the connector strip, it appears not to be connected to anything else unless there's a jumper strip to the next connector. The next connector is one of the yellow wires to the rectifier. The rectifier has 2 yellow wires and a red one. I guess it could be bad, I think you test it with an ohm meter somehow. Should I connect the grey to one of the yellow wires from the rectifier???
