KrazyKyote
- May 12, 2011
- 10
I have an older boat with a 1978 johnson 25 hp sea horse model number is 25E78C motor.. it has no pull start and is only fired by a key.. I looked at the black and yellow wire and cannot figure how to disconnect it , its all harness.. It also has a fully charged battery and no corrosion anywhere and turns over nicely but wont fire.. I'm guessing this motor is electric start so it has nothing under the fly wheel to go bad..I have read alot online about the power pack and un plugging the black/yellow wire but cannot figure it out to diagnose it..The boat did run last time out, that is where it had died on me right at the loading ramp and has had no spark since.. I just figured it was fouled plugs at the time.. Hopefully somone can help..Thanks
