Hello. I thought I had finished making my Evinrude 25hp Big Twin a relaible motor when I noticed that I had to replace the gear set and clutch dog on its first lake test. I ordered a brand new gear set and clutch dog, took off the lower gear case, and got every thing back together in the lower gear case. When I went to mount the case with gears to the lower unit, I noticed water was coming out of the lower unit when I tilted the motor back to install the gear case. I didn't have an oil leakage problem before as the oil was water free. Is it normal for water that collected up by the water pump or exhaust to pour down once I released the lower shift rod or or did I create a problem that needs to be fixed. I feel that I'm almost done with this motor and want to make sure its right before I put the gear case back on. Thanks a lot for your help!
