Re: 1963 Johnson V75 V4AL15E Voltage regulator
Don't guess, test. You sound like you have the service manual.
With the key on and motor not running, you should have 12V at stator's red wire and 0V at the stator's blue wire (because it is grounded through the regulator). BTW, if grounding the regulator's field terminal doesnt make it charge, it is not a bad regulator.
Personally, I have never seen a bad stator, but I suppose all things are possible on a 48 year old motor.
I suspect a broken wire, a bad diode, or the 60 amp fuse. You say you have tested them all. What else can I say?
Test everything.
