chunkymonkey
- May 4, 2011
- 7
Hey all,
My name is Mike, I just joined the forums after a massive amount of Googling led me to this place. Good to be here! I recently purchased a 15ft Rinker with a 1977 Johnson 85HP on the back. Appears to be in good shape, but it doesn't run at the moment. The motor turns over fine when I turn the key. The toggle switch for the choke and the throttle cables seem good too. Fuel is getting in although I should probably clean the carb. So I took out the spark plugs, held them against ground and turned the motor over....no spark on any of the 4 cylinders.
Before I start asking what's wrong, I do see two potential problems. There is a black wire coming out of a small rectangular plastic box (I believe this is the power pack???) along with another black wire that comes from somewhere else (will trace it to source) that are not connected. Are these ground? Do they just connect where all the other ground wires go?
Please let me know where to connect those two wires. Can try to get a picture?
If that fails, what should be next on my list to check? Do I follow the directions in the top secret thread to jump my solenoid? Should I disconnect the black and yellow wires? (there is no kill switch though that I see..only the key). What should I start off doing?
I'd rather not pay $115/hr for a mechanic and tons in parts if I can fix this myself, so any help is appreciated.
Thanks!
Mike
Thanks!
Mike
