Re: 79 100hp Evinrude Tach??
Wilde1j is correct of course. I would add the following.
You need a tachometer that will operate off of a 6 pulse charging system, available on this site no doubt and your dealership. The tachometer will have a dial on the back of it which should be set on number six (6 pulses).
These tachometers usually have four wires running from them in the colors of: Black, Blue, Gray, Red.
Black connects to ground. (Self Explanatory)
Blue connects to the light switch. (Illuminates tachometer when needed)
Gray connects to the Gray lead that normally protrudes from the wiring harness. (Signal Sensor)
Red connects to the "A" (Auxiliary) terminal of the ignition switch. (12v when key is ON)
