binpointlanding
- Jul 11, 2010
- 1
I only use this motor 2 times annually, but the head gasket keeps blowing out in the same spot. There are points where the gasket is only 1/4" wide and that is where it keeps failing. Is there a better gasket material than the compressed cardboard pre made gasket that I'm using. And yes I'm putting the gasket on dry, and torquing in the proper sequence. At this point, I'm afraid to take out the boat!
